scrub12
- Cleveland, OH
- Electrical Engineer
In addition to the EGC being ran with branch circuits to panels and loads downstream of service entrance equipment - I've often seen supplemental bonding to building steel or ground in addition to the EGC ran with the branch circuits. Is this supplemental ground required by NEC? In other words, do panels and motors specifically need an additional ground conductor connected to the building grounding system in addition to the EGC run with the branch circuit? I've also seen MCC's bonded together. Is this a code requirement or just a supplemental good to do to make sure all conductive material stays at the same potential?
