Shane Platt
- Safford Arizona
I work for a mining company, and common practice is to run a ground wire with all phase conductor feeding a piece of equipment thats normal. But they also run a external ground and attach it to the equipment I.E. motor, machine, etc etc. This EGC is not in the same pipe nor is it always coming from the same grounding source. Our safety dept thinks driving a ground rod and bonding the equipment is the solution for static shocks that sometimes occur(Even though there already is a ground that is bonding the cabinet and the equipment with the phase conductors). On the other hand I have some concern about parallel paths to ground, seperate grounding systems, and ground loops. Is there any safety concerns with this? And does the code or some other literature directly address this issue?
Thank you
Thank you
