michaelv
New member
- ravenna ohio usa
I am purchasing a home in Ravenna Township and during my home inspection the inspector and I noticed that the service was improperly grounded. Long story short I insisted it be grounded properly and the contractor the owner had out said it was fine. I still disagree. Here is the scenario. The service is 400 amps, has one meter base but two 200 amp panels fed through two separate 2 inch PVC conduits.There is an in-law suite on one side of the house and the home is all electric, so two of everything except hot water tanks. At the service entrance, which is overhead, there is only one ground rod which has a #6 bare conductor grounding the neutral at the meter base. There is no grounding/bonding conductors through the PVC pipes into either panel. In each panel the bonding screw is driven into the panel. Only one of the panels is taken to the cold water line. There is no bonding conductor from one panel to the other. The home has well water and PVC pipe from the well to the house. In my opinion there is no supplemental ground to the house and should have another driven rod. I also believe there should be conductors from the meter base connection point to the panels as well. Am I thinking correctly or are the bonding screws and one rod sufficient?
