shortcircuit1
- USA
Hello,
I have a 4000A switchboard, 200A service for fire pump and lastly a 1200A service trough. All three laterals fed from the same transformer.
If you have one building/structure with 3 laterals from the power company transformer, do I need to design a grounding electrode system for each lateral or do you just use one common grounding electrode system for the building, have a common grounding electrode and then bond the services from the common grounding electrode? If so, how do you size the bonding wire from the common grounding electrode to the other services.
Thanks.
Thanks.
