Hwill
- Denver, CO, USA
I have a quick question regarding bonding requirements in C1D2 locations where the source is a simple TEG or solar powered system. The application is a an RTU powered by a TEG or PV system outputting no more than 30VDC. RGS is ran from RTU to switch on top of a valve actuator that sits on a pipe (pipeline). The pipeline is CP protected, so typically we isolate the conduit with a phenolic coupling just before it terminates into the switch box on the pipe. Art 250.100 was brought to my attention as to why the phenolic would not be appropriate. Does art 250.100 apply in this case, given conductors are not being supplied by a service, and there is very limited risk in the non-current carrying metallics becoming energized?
Thanks.
Thanks.
