Brett Glass
I'm a wireless Internet service provider. I have a job coming up that involves installing radios on several trailers at a large construction site. These trailers are literally staked into the ground, with huge metal stakes, so they won't blow over. Electrical wires run from a meter at the edge of the lot to a breaker panel in each trailer. The ground bus of each panel, and the neutral wire of the electrical feed, are bonded to the heavy metal undercarriage of the trailer. Since I see nothing else driven into the ground I assume that they're relying on the stakes to serve as ground rods.
I'm thinking that this makes the metal undercarriage of each trailer essentially equivalent to the frame of a metal building, and that it therefore can be used as a ground for antennas for radios. Should I bolt a lug to the undercarriage and ground to it? What is the best and safest way to ground the antennas and antenna masts in this situation?
