I'm doing a "utility installation" for a personal residence.
The design is a 320A meter socket that feeds 2 x 200A service mains.
The 320A meter socket will be wired (utility side) by the utility from a 15kv step down transformer.
I'd like a little assistance correctly grounding the meter socket and double checking my wiring of the 2 x 200A panels.
On grounding the 320A socket, the utility specifies:
"Grounding bushings shall e used on the inside of the meter socket, panel, or panels, attached to to grounding bus bar with #6 copper grounding conductor. Regular locknuts shall back them up on the outside of the meter socket, panel, or panels.
