a 100amp panel is located adjacent to a small steel bridge over a pond,
1.the question is regarding the touch potential of the steel bridge,
the panel is bonded to the steel bridge and a egc is run to a rod,
the panel is fed from a sds 1 ph 480/240/120 in a bldg 130 feet away, there is no egc run with the feeder conductors.pvc conduit.
the neutral is bonded to the egc/rod/bridge
is this a safe installation?
the bridge is bonded to the panel by screws, is the shock /touch potential greater in the event of a fault?
the panel feeds 2 small 120v fountain pumps run 24/7 and tree lights, this is a public pond. pumps are on gfci receptacles.
