dvolsr1
- oak ridge tn.
i have a friend who has a fixed boat dock and power from main panel TO A SUB PANEL was run without a EGC .( this is a fresh water lake) question one ,do you isolate the bare netural. 2. do you ground the panel to a ground rod.or can you isolate netural and not gnd. panel to gnd. rod and use a 2pole gfci for shock protection from faults . i know the proper fix is to run a EGC, BUT THI A 300 FT. UNDERGROUND CABLE .THIS IS A 240 VOLT PANEL.
