JDB3
- San Antonio, Texas
Asked this before, but can not find it right now.
Utility company ran their service drop to secondary pole where, ONE electric company built their service consisting of: riser with wires feeding into meter socket & then to the disconnecting means on the pole. From there they ran some 200 +/- feet (underground) to electric trough mounted under the 2 200 amp panels on the residence.
SECOND electric company had wired the residence, installed the 2 panels & trough.
{A} Should this be a 4 wire system (2 hots, 1 grounded [neutral], 1 grounding [ground] ) from the disconnect on the pole to each panel? :?
{B} Should this system be bonded to the re-barb in the slab (that has plastic between the ground & re-barb & have a proper ground rod? :?
{C} Should this system have a ground rod by NEC, at the pole OR would the power company's but ground on their pole suffice/ :?
Please give the best code articles reflecting answers. This is a big dispute between the 2 electric companies & I am trying to help the owner with this (a good friend of a good friend). Again, thanks, one & all! :happyyes:
