hackman
- California
- HVAC & Electrical Contractor
I have come across a residential home that has the meter & disconnect switch on one side of the house then the entrance cable goes up to the attic (single story home) then on across the attic (roof joists) then down to the basement into the load center/main breaker panel (100' total run). Due to the distances of the entrance cable there are ground rods at both the main outdoor disconnect switch (req. per NEC) & the load center/main breaker panel. The only point of bonding is at the main outdoor disconnect. Thoughts?
