Eeyore's Tail
- Tukwila, WA
- Sparky
I've got a 500 kva Medium Voltage Wye-Wye Pad mount Transformer outside with combined H0/X0 on the secondary side - 12,470V to 480V. Outdoor 480V panel located about 20 ft away on the same concrete pad. We installed a Ufer ground with 3/0 bare copper attached to the rebar in 2 places just in case. 2 ground rods installed and a GEC run to the panel before we knew what was going on with the Ufer ground.
Read a bunch of conflicting things on grounding and bonding for this and not sure why they got a Wye-Wye transformer. How would you do ground and bonding between transformer and panel? Crappy sketch to illustrate
