Grounding / Bonding Multiple Dwellings
In a multiple dwelling (4 Units/5 Meters), with one main disconnect for the entire service entrance, are the individual load centers treated as sub-panels(isolated ground and neutral) or as main panels?
The main disconnect is the service, everything downstream requires an EGC and isolation of it and the neutral.
Roger
Are the meters load side of the main service disconnect, if so the grounded conductor (neutral ) can rebond in the meter enclosure (s). The meters / individual meter enclosures would have to be adjacent to the service disconnect
past the meter enclosure you would need the neutral to isolate from the equipment grounding
