Is there a reference or a requirement for the installation of a ground rod at each pole base. What I am refering to when I mention pole base is a concrete pole base which supports a 20' to 30' metal pole. The luminaire is then mounted at the top of the metal pole.
The circuit has an equipment ground. I have seen pole base details which indicate a ground rod at each pole base. Then a bonding conductor is attached to the metal pole & the rebar within the pole base.
Is there an code reference for the requirement of the ground rod?
