Im very cofused, Im learning that many electricians do not know or even care to know  the real reasons behind the service neutral and grounding.Please is there someone out there that can explain this to me and convince me that you are right,seeing im getting five different stories.Is the neutral from the transformer on the street to a 240/120 residence really grounded or not? and what is its function? Is it supposed to open circuit breakers in case of a short circuit? Is it supposed to open breakers in case of a ground fault,or both?Whould the breaker trip anyway even if i lost the neutral somewhere along the line?Would the water pipe and groung rod be able to accomplish this if i lost the grounded neutral?and if not why?why? am i learning that earth grounding will not clear a ground fault? what about a short circuit?Is resistance of the earth great or not?Isnt the circuit breaker thermaly protected anyway? Why would i need the neutral to trip it What is the use of a ground rod anyway if its only good for 4.8 amps maximum current at 25 ohms.If a breaker is thermally and magneticly protected how about a bus fuse.? By the way if the grounded neutral is bonded to the grounding electrodein the main disconnect why does,nt some return current flow over the waterpipe and electrode as well as the neutral ? if so isnt this dangerous?why is it so hard for electricians to want to know this. I feel as an apprentice it is imperative to understand all of this but what is frustrating is that Im getting half a dozen different stories even from my teacher or is it not many truly know anyof this.PLEASE HELP
