Im very cofused
russ Senior Member Location Burbank IL Feb 24, 2004 #2 Re: grounding,bonding The spell check may help. In the mean time make an appointment with your psychiatrist, and try to stay calm.
H hurk27 Senior Member Location Portage, Indiana NEC: 2008 Feb 24, 2004 #3 Re: grounding,bonding I hate when that happen's LOL
russ Senior Member Location Burbank IL Feb 24, 2004 #4 Re: grounding,bonding OK I'll play Freud, what seems to be the problem?
H hurk27 Senior Member Location Portage, Indiana NEC: 2008 Feb 24, 2004 #6 Re: grounding,bonding Take two GEC's and a couple of Listed clamps and call me in the morning. :roll: [ February 24, 2004, 07:55 PM: Message edited by: hurk27 ]
roger Moderator Staff member Location Fl Occupation Retired Electrician Feb 24, 2004 #7 Re: grounding,bonding If you are really cofused (CO - FUSED) you are probably in violation of 240.8 Roger
H hurk27 Senior Member Location Portage, Indiana NEC: 2008 Feb 24, 2004 #8 Re: grounding,bonding Now I'v got dereck doing it to me. LOL Look at our post time
russ Senior Member Location Burbank IL Feb 24, 2004 #9 Re: grounding,bonding bond: Go to the search section next to Member Directory and put Ground or Bond in the search box and a whole bunch of past discussions will come up. If that doesn't help try wrapping your head with aluminum foil.
