Can you tell me the Code for grounding branch panels? This is a data center with 480v-in 120-208 out PDUs which I assume have proper ground-neutral bonding, being a "power source". We are running 60 amp circuits from 2 PDUs to 2 125 amp branch panels, then to individual 20 amp 120v Smart switches which will do a fractional-cycle speed transfer from one input to the other in case of failure. I maintain that the ground and neutral should not be bonded, but I am meeting a lot of "all the other (non-UPS/PDU) panels are bonded" and "they do it that way at the other place". Besides quoting Code, what problems could occur from this incorrect bonding?
