Keri_WW
Background:
I'm designing an addition to an existing building. The new addition has a separately derived service (I think); however, the main feeder to the exterior transformer that is feeding the addition's switchboard originates from a substation in the existing building.
Questions:
Thanks for the help,
Keri
Questions:
- Does the grounding system for the existing building and the new building get tied together?
- Does a grounding equipment conductor need to be run between the outdoor switch and the exterior transformer (basically, where is the grounding for the exterior equipment derived?)?
- Does the lightning protection have to be tied together between the two buildings (the addition is a bit shorter than the existing, however requires LP past the zone of protection points).
Keri
