infinity said:Probably not. You need to provide more details. There are many variables to consider.
buckofdurham said:You only need grounding bushings on one side of the conduit or the other.
buckofdurham said:You treat it like any other metal conduit installation. You only need grounding bushings on one side of the conduit or the other.
Is it necessary to install grounding bushings on the secondary conduits in a seperately derived system such as in a transformer installation.
timz said:The liquidtight conduit is 3inch in size and feeds a lighting panelboard from the secondary of the transformer. they are clean punched holes, no concentric knockouts, 208/1210 volt system. liquidtight conduit provided for flexability.
