SEAN CONWAY
New member
Today I Came Across A Panel For Power And Lighting W/ 60 Amp Feed The Bx Riser Connected To Consentric Ko Do You Need A Gronding Bushing To Asure Groung On Pannel?
(I believe my answer is correct here..if not, more learned will advise)SEAN CONWAY said:Today I Came Across A Panel For Power And Lighting W/ 60 Amp Feed The Bx Riser Connected To Consentric Ko Do You Need A Gronding Bushing To Asure Groung On Pannel?
if its service equipment then you need a bonding bushing on the metal connector containing the service conductors.SEAN CONWAY said:Today I Came Across A Panel For Power And Lighting W/ 60 Amp Feed The Bx Riser Connected To Consentric Ko Do You Need A Gronding Bushing To Asure Groung On Pannel?
electricalperson said:if its service equipment then you need a bonding bushing on the metal connector containing the service conductors.
