grounding bushing
More facts are needed to tell you for sure, but if the disconnect has overcurrent protection and the system is <250 volts to ground, probably not.
You need to review 250.92(B), 250.96. 250.97, & 250.98 to see if any of those situations exist.
Like Augie stated there is no direct answer given the information provided. One would need to know if this is a service raceway (not likely given your description), the voltage, and the type of KO's being used.
