jusjj
- opelika, alabama usa
i have a general application where i have 120/208 and 277/480 volt branch panels with blank end panels. The end panels are punched to the proper size, then rigid conduit leaves the panel, travels under the slab, converts to pvc, then converts back to rigid when it penetrates the slab at its destination,; to a box, controller, or other enclosure, always having the appropriate size hole punched. Are grounding bushings required at the termination of the rigid conduits??
