grounding bushings
The most common use, IMHO, is on service conduits when concentric or ecentric knockout as encuntered. See 250.92 for services and 250.97 for bonding over 250 to gr will give more specifics.
If there are no conecentric/eccentric knockouts, a grounding locknut migh suffice.
In general, grounding bushing are used to maintain an effective ground path when needed (around knockouts, etc.).
In regard to your specific question, you wouldn't necessarily need a gr bushing at reducing washers unless you were dealing with 250.92 or 250.97.
Secondly, and EGC in the conduit would not remove the need for a bushing to ground the conduit itslef.
