grounding BX
i have a 3 gang plastic switch box that has BX cable and romex running through it. Homeowner used a cable clamp attaced to each end of the BX to continue the ground. I would replace the plastic box with a metal one but this would require plaster work and the owner doesnt want to hire a mud man....will the ground wire cable clamped to each end of the BX be sufficient?
