Grounding chains
dwayner
New member
Does anyone know where I can find the correct way to install, and at what point in distribution to install grounding clusters? Nobody at work seems to really know...
Your title says grounding chains, and your question says grounding clusters.
Would you mind explaining the terms?
(I thought you were going to ask how to bond a section of chain.)
" Ground chains " is old terminology . Some folks still call them that .
Where , depends on what you are trying to ground and where you plan to work . I have some info on Equipotential grounding that I can send you .
