Fredkehoe
New member
- Newburgh ny USA
I am doing a small renovation job in which there is existing two conductor BX cable in the house with no ground except the BX cable. The building inspector wants the box grounded with the wire to the new outlets. Are those green grounding clips that clip on the edge of the box OK? Or does the boxes have to be drilled and tapped and a ground wire screwed in?
I appreciate your help.
