Fmkehoe
- Cornwall ny USA
- Inspector
Can someone direct me to the section of the code that allows for grounding clips on old two conductor outlets.
Can someone direct me to the section of the code that allows for grounding clips on hold two conductor systems
Old house, some renovation done in the house, building inspector now says that the old non-grounded outlets have to be changed for grounding outlets. There are clips that can attach to the metal gem boxes that will provide a grounding pigtails to the new outlet.clarify please.
Just need to know that those grounding clips are up to code.
The ground is coming into the box by means of the metal bx cable attachesd to the box. So the box is grounded, but, even tho the outlet is attached to the box is technically grounded, it is not legally grounded.
Look at 250.148(C).
Do the above self grounding receptacles comply with 250.148(C)?
250.146(B)
