#8 thhn copper wire,3 conductors, 3 phase, 208 volts in a 1 inch sch 40 pvc conduit,suppling 12 parking lot light poles. two heads per pole. 20 amp 3 pole breaker.wire length of run apx.1000'
question- can the grounding conductor be a #12 thhn? this is the present installation,and the engineer spec'ed ground rods at each pole. poles are fiberglass, heads are metal and transformer base,also metal.
