Nelson electric
Christian
- Sacramento, ca
- Electrician
A residential client had a new solar array installed alongside with a new 400 amp panel at array. Then had a 200 amp sub feed to existing home 400' away and did a new 200 amp panel, with parallel 350 Al in same conduit
without a grounding conductor. The contractor said no ground was needed whereas I disagree.
Can you verify for me if that is safe and to code?
