At an industrial site, I'm installing a new 2500kva pad mount 13,800v/480 volt pad mount transformer which will feed a 4000 amp magnum drawout breaker. I plan to feed the 4000 amp gear with ten parallel conduits with 500mcm copper feeders in it, no neutral to this system. The question is can I downsize my grounding conductor in each of the conduits or does the grounding conductor have to be the same size as the feeders?
