petersonra Senior Member Location Northern illinois Occupation Semi-retired engineer Jun 10, 2022 #1 So what is this yellow cable? Saw it at a KFC at lunch. Tracing wire?
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician (retired) Jun 10, 2022 #2 You connect a toner to it to send out a signal that is traced above the ground. Used for marking the location of the buried pipe.
tom baker First Chief Moderator & NEC Expert Staff member Location Bremerton, Washington Occupation Master Electrician Jun 10, 2022 #3 Most ug natural gas lines are now HDPE. Hence the tracer wire for a toner.
