jbinspect
- Kansas City
I inspected a group of duplexes, tri-plexes and four-plexes built in 1983 that had significant issues I know would not fly today. My problem is not knowing what would be grandfathered and how to report the issues. Here's a description of the existing installation: Meters outside
100amp Square D panels in kitchens, fed with three #2 copper conductors and one #8 insulated stranded copper grounding conductor.
NO remote disconnects outside, 100 amp breakers in each panel.
Entrance cables are very long ? sometimes 30? or more (again, no remote disconnects).
The system ground driven rod conductor comes into the meter can, then each unit's #8 grounding conductor is connected to the rod.
Branch circuit grounds in each panel are twisted together and clamped onto one lug attached to the back of each panel and the #8 conductor is also attached to that clamp. See photo. These units were built as low-income dwellings for the municipal housing authority so it seems inconceivable to me that all these things were violations back then, but.... Thanks in advance for the help.
