Had a situation the other day (swimming pool) where I connected a #8 copper solid bonding wire to a #8 thhn green grounding conductor under the SAME mechanical lug. I installed this lug with a bonding screw to the metal can of a 60a/250v 2pole safety switch. The AHJ didn't knock down the instalation but said that the two conductors should not be under the same screw. :roll:
I think that a ground fault would have to depend on continuity from wire to wire through the lugs. The better of the two connections would be a direct wire to wire connection under one lug. Please advise and or site an NEC referance that promotes or prohibits this.
Thanks, Mike -- Michigan
