My question is on grounding the secondary of a small (2KVA single phase) control voltage transformer. One tap X2 is desginated as neutral/ground and the other tap X1 is for the hot wire. To ground X2, must the wire be connected directly from the ground bar to X2 or can the ground wire be connected from the ground bar to the neutral terminal strip. The neutral terminal strip is connected to X2 via white wire. I know that the perferred practice would be to do a direct connection, but is it spelled out in the NEC code?
Thanks
Rob
Thanks
Rob
