djwireman
- Denver Colo.
How should I ground a circuit that has hot and neutral but no grounding system? I've fixed the problem in the past with grd screws and tails but I recently came across one that showed open ground even with the install. And I thought of using a supplementle ground, jumpin the neutral but was reluctant to. And wanted to see if any one else has experianced the problem and possible resolutions. Even with tails and grounding screws still reads as an open ground, and not practical to run egc to water pipe, or if clients refuse to purchase a new circuit.
