alblock
- NC, TN, SC
- Industrial Electrician
We have several CNC machines that are ungrounded. Most have 480/240 delta delta transformers sitting right on the machine. We have been told by Mitsubishi, Fanuc, and other machine tool technicians that is part of a problem we have been having with NC units going bad. I will order or machine copper bars for dummy fuses. Can I just bond the incoming B phase at the disconnect switch and call it a day?
I know I have to run a GEC, SSBJ, EGC, What other requirements do I need to do to be 2014 NEC code compliant? I made a rough diagram using drawio.
Thank You.
Thank You.
