electricontr
We installed a new service on a garage and fed the house overhead from the garage with a fourplex loop, two hots, one neutral(grounded conductor) and a bare grounding conductor. We drove two ground rods at the garage. We also connected a #6 cu from the water service to the panel on the house. In my mind, the house is grounded by the the water service pipe and the grounding conductor from the ground rods at the garage via the fourplex grounding conductor. The inspector disagrees. He says that we need ground rods at the house too. Comments
