Grounding Diagram
LevinhoMills
Lagos Nigeria
Electrical Engineer
How do I Indicate on the grounding diagram the grounding of gas lines and low-voltage systems (HVAC drawings show gas heaters in the units)?
There is no need for the additional bonding of traditional gas piping if there are any appliances that use both gas and electricity.
There is an issue of some types of CSST gas piping is used.
Some local codes want gas pipes bonded together at the meter because the meter isn't conductive. Bare yellow wire etc. Not sure what they require where you are. Some local inspections don't even care if the gas is bonded.
The local inspector here in CA, is insisting I indicate on the grounding diagram the grounding of gas lines and low-voltage systems. I recently submitted a plan for approval. you have idea how i can go about it?
