- Bremerton, Washington
There is much confusion on grounding and bonding. We as a trade most often use grounding when we mean bonding. The 08 NEC has a great definition of ground.
It would much clearer if we said earthing when we mean grounding. The if someone says you need to run a ground wire, it would be you need to run an earth wire.
So my proposal is change the title of the this forum to Earthing versus Bonding.
