pclendenen
Can anyone direct me to the code that deals with grounding electric fences, and if grounding to water supply lines is prohibited?
Yes it has to be earthed in order to work or complete a circuit. The units I have worked with can use either your facility ground electrode system, or a seperate electrode. As Tom and I have stated it is a UL issue.Originally posted by pclendenen:
I believe that the fence does indeed need to be grounded. When you then touch the fence you complete the circut. Am I correct?
