danno1202
- Mounds View, Minnesota
[ONFIG]12534[/ATTACH]
I am in the process of installing this service. One panel is for normal power and one is for off peak. The panels will have separate runs to the remote meters. My question is, do I need two separate grounding electrodes, or just one? There is also an exposed re bar from the foundation nearby that the builder might have intended to be a ground connection point. I am planning on connecting the meter enclosures via the grounded neutral conductor, no separate ground seems to be necessary between the meters and the panels.
