Grounding Electrode Conductor Size for Dual Services
stevero
I am upgrading my service to a dual meter service - one for the general house service,and the other for electric heating which is billed at a separate rate. Using my local utility's standards, I will set a new 400-amp meter socket with new weather head and 500 kcmil cu conductors to the service side of the meter. I will jumper between the service-side lugs on the new meter socket to the service-side lugs on the existing 200-amp meter socket with 2/0 cu conductors. Each meter socket will connect to separate 200-amp load centers with 2/0 cu conductors.
My local permitting agency says I need 1/0 cu ground electrode conductor (for 400 amp service). I say I need #4 conductor for 200 amp service. It seems to me any ground fault would be cleared by a 200-amp main breaker, therefor sizing for 200 amps should apply.
Who's right? (BTW, I will run the GEC from ground to one panel, and then jumper to the second panel - 16 inches away.)
Re: Grounding Electrode Conductor Size for Dual Services
1st tell us what the electrode is?
If it is a metal water pipe, then you can run a common 1/0 GEC from the water pipe and tap a #4 to each 200 amp disconnect...or run a seperate #4(two continuous runs) from each disconnect to the waterpipe...250.64(D)
see exhibit 250.26 2002NEC handbook for example...
shortcircuit2
The water pipe is my primary ground. Also have a ground rod.
As I understand the code, the GEC must be unspliced. Won't the idea to tap two #4 wires from the 1/0 violate this? I'd rather take #4 wire to the panels, as I don't think my ground lugs are big enough for 1/0. Maybe the best is to run dual #4 wires as you suggested.
stevero...2 ground rods a minimum of 6 feet apart to supplement a water pipe unless the 1st is 25ohms or less.
Did you look at the example in the 2002NEC?
The 1/0 can stop, lets say above the two 200 amp panels and then tap a #4 (with burndies for example) into each panel.
shortcircuit2
Originally posted by stevero:
...I will set a new 400-amp meter socket with new weather head and 500 kcmil cu conductors to the service side of the meter.
...It seems to me any ground fault would be cleared by a 200-amp main breaker, therefor sizing for 200 amps should apply.
See Table 250.66. You need a 1/? CU water bond. It's based on the size of the ungrounded conductors feeding your service, not the ampacity of any breaker you install.
Edit to add: I'm confused at why this is being made tricky with the inclusion of #4--if the two disconnects are 16" apart, why not just loop through one and hit the second with the 1/?? :confused:
Edited again: If there is an existing drop, and you're adding a drop, why not just size the second drop for 200 amps, and forget about it? :confused: :confused:
[ March 05, 2005, 08:58 AM: Message edited by: georgestolz ]
The GEC is not part of the fault clearing path, so this logic does not apply. The size of the GEC is based on the size of the incoming conductors.
