WorstJobIveEverBeenOn
- texas
- helper
I'm kind of confused on the terminology of what is a grounding electrode conductor is and where it becomes an EGC, bonding jumper or if its all a GEC.
For example, If I go from my ground rod and run up a column setting a ground terminal bus bar on each floor, then go from my GTB to ground a pipe on the roof, would every conductor connecting each of these points be referred to as a grounding electrode conductor. Or does the wire become a bonding jumper or EGC when I go from the GTB to the pipe?
In my head, the grounding electrode conductor is the connections between building steel and the ground rod and all my connections for equipment, pipes, floor pedestals, ETC tied back into the GTB would be bonding jumpers or EGCs. Any help clarifying this would be greatly appreciated.
