karl riley
Since there is so much attention given to lowering grounding electrode impedance, it is interesting to consider what would be the results of routinely obtaining very low ohms.
Suppose a new system came on the market to get the ohms down to 1 ohm. (Actually, an EMF expert I know has suggested that should be our goal, now that water pipes are becoming plastic).
If this were achieved, every building would dump a percentage of its neutral current into the ground as a parallel path back to the transformer. There would be current flowing in the earth throughout the neighborhood. For livestock a potential would develop between front and rear hoofs. "Stray current" would be a common problem.
Any other ideas about what the results would be?
Is it possible that 25 ohms is actually a good gate-keeper for our system? (except in electronic environments where lightning is a problem).
Karl
Karl
