BackCountry
- Southern California
- Licensed Electrician and General Contractor
We have a few ground mount solar arrays in the job queue, and as I was doing takeoffs to prep for material orders, I wondered... do 16 helical piers embedded 5’+ into the soil supporting a ground mount solar array, with a UL2703 compliant racking system that’s bonded throughout, qualify as the grounding electrode thereby eliminating the need to drive a second ground rod? These are microinverter based systems, so the entire array is bonded, and no DC leaves the array, It’s all AC. We have a pier mounted AC disconnect where we will tie the ground in from the main panel. From there, we’ll have a #6 bare copper that’s bonded to the racking and frame. Clearly driving an additional ground rod isn’t expensive or difficult; however, logically speaking it’s difficult for me to think that it’s doing something when I’ve got 16 galvanized piers with 5 feet of direct earth contact each right next to it. Please educate me, when reading the NEC steel structure used as a grounding electrode or UFER ground sections, my situation does not appear to clearly qualify.
