I have read article 690.47. It is still unclear to me if the grounding electrode system part of my install is code compliant. My company does a lot of residential pv systems. The Solar GC mounts the panels on the roof, drops a line down to the inverter and then we take it from there. Where I am most installs go like this, from the inverter(s), to a A/C combiner panel, from the A/C combiner panel to a disconnect, from the disconnect to a dual meter socket enclosure that houses the pv meter and house meter w/one riser going up for the utility connection. These installs vary in their design at times, but you get the idea. We have always pounded two ground rods, hit the pv system service disconnect and called it a day as far as the GES is concerned for the A/C side of the installation. My team and I have passed many inspections this way. I have been told explicitly by at least a handful of inspectors that this is sufficient. I have one inspector at the moment requiring us to also bond to the homes GES, if they do not have one he is requiring us to install one, and bond to it. I would appreciate any clarity any of you can offer here. Is this one inspector correct and everyone else wrong, is everyone else correct and he is wrong or are we dealing with a gray area. Thanks everyone.
