joeyww12000
- Chatsworth GA
When building the grounding electrode system for a new construction service you must use all grounding electrodes available.....steel, ccee, groundrod, first 5ft of water pipe......You can either take one grounding electrode conductor to first electrode then bond each seperate electrode or take seperate grounding conductors to each electrode....my question is does the connection point at the service for your grounding electrode conductors have to be made at the grounded conductor bonding point of your service? Say you have a disconnect outside where your grounded conductor makes its bond and a system bonding jumper is ran inside to a MDP and terminated to the enclosure....can you make your terminations for your grounding electrode conductors in the MDP...? or must they all be taken outside to the service disconnect?
