hhsting
- Glen bunie, md, us
- Junior plan reviewer
Attached sketch shows underground water pipes come up in building from under ground. One line sketch shows how the underground water pipes are interconnected underground.
Panel X has grounding electrode conductor going to each of the underground water pipes.
I am not sure if the water pipes are electrically continuous each other or not.
I had some variation of this post in past but that only left me more confused
Question:
1. The shaded part in one line assume its Not electrically continuous and 10 feet or more in ground. Would each water pipe require connection from Panel X or not?
2. The shaded part in one line assume it IS electrically continuous and 10 feet or more in ground. Would each water pipe require connection from Panel X or not?
Question:
