NEC 250.52 says that (1) Metal Undeground Water Pipe (2) Metal Frame of the Building or Structure (3) Concrete-Encased Electrode (4) Ground Ring (5) Rod and Pipe Electrodes (6) Plate Electrodes (7) Other Local Metal Underground Systems are electrodes permitted for grounding.
My question is how many electrodes mentioned above are required for a grounding electrode system? Do I need get all of them? If I have (1) (2) (3) available, do I need get the rest especially (4), (5) and (6)? Normally I will do (5) Rod Electrodes.
Thanks in advance.
David
Thanks in advance.
David
