I work for an electric utility and recently encountered a large customer using a 250VDC system(two 125VDC Battery banks in series) for control and relaying on their switchgear. They intentionally grounded the center leg of this three wire battery system. We are using a tap of one of the 125VDC banks for control and relaying of the transmission equipment in this customer substation. We normally leave our 125VDC battery banks ungrounded and check for grounds using a ground detector. My question to the forum is this: Does the NEC require an intentional ground on 250VDC battery systems?
